Clx-9201 stuck on boot screen
  • gregorc
    • Dec 2021
    • 5
    Re: Clx-9201 stuck on boot screen
    Originally posted by Arcadian
    bootloop could be several things, bad hdd, bad main board or bad screen board.
    try disconnecting the hdd first see if reecovery mode ccoomes up, if it does then hdd is bad find another 320 hdd prefer a Western digital. then try to flash a recovery to it see if that fixes the issue. if you have another machine you can move the hdd to it to see if its the hdd on it.
    if its the main board the only way to test that is to try to format the hdd if it fails on a new 320 gb drive then main board is at fault.
    if its the screen board, you need to replace the board behind the screen.
    good luck.
    Thank you for very fast reply.
    I'm able to print over network. I was also able to update firmware with SyncThrough, where everything is marked as "completed", but "UI" is "progressing" and never ends.
    I tried restarting printer multiple times and few times I was lucky and display came alive. Everything was working at that point. But after next restart I was stuck at Samsung logo with spinner.
    I was wondering if I could somehow try to upload new firmware to the OPS (screen board) directly via usb. If I use *0# i get message "waiting to download firmware ..." but I don't know what to do from here on?
    If screen-board is defective - has anyone investigate this on component level what is causing problem?
    For anyone with C9301 who is wondering how to upload firmware with SyncThrough (when there is no firmware upload button) - you have to go to "Applications" and then "install" and upload .hds file - after that you will see dialog for updating firmware. Took me quite a while to find that.
    Regards,
    Gregor
    • gregorc
      • Dec 2021
      • 5
      Oh and I forgot to answer that regarding HDD - I tried disconnecting HDD and display is still stucked on "Samsung" logo (spinner spins about 3 times and freezes).
      Regards,
      Gregor
      • gregorc
        • Dec 2021
        • 5
        After few restarts I was lucky to get system booted into UI. I was pressing "STOP" button on start, but I'm not sure if that was the key.
        Once I was in UI, I was able to update UI firmware from there.
        After that everything works.
        It looks like screen board is ok - it is just that firmware is corrupted.
        It would still be interesting to know how to update UI firmware with *0# ...
        good luck.
        • Shan2091
          • Nov 2016
          • 13
          #19
          Originally posted by fornerm
          Hello,
          i have the Same, the Failure is FW Version V6.P6.O3, the latest FW, this is the failure, you Flash with an older FW example V6.O6.09 to fix this.
          The FW you can download from HP,the latest, ist Fault.
          mfg
          Hey do you have the old firmware of Samsung MultiXpress 9201 because it's not web anymore
          • Crowfeather
            Printer firmware is !&$!
            • Mar 2021
            • 130
            #20
            Afaik, the direct link for firmware download on the HP website is to an ftp server that you can access directly by shoving the direct link address into windows explorer as some guy was circulating the general ftp link on the HP forums a while back.
            Might find something there if you look around.
            • mhanes@sdwp.com
              • Jun 2014
              • 10
              #21
              I have the same issue. In my case the model is CLX 9301 and it is somewhat of a bootloop. I can hear initialization of the motors and I even removed and tested the HDD and and can hear it working. I have tried the firmware load option with 3 files and none of them seem to work. Just see the FIRMWARE DOWNLOAD MODE Ready to Receive Firmware... screen but no progress.
              Tried:
              -Samsung_CLX-92x1_93x1_Series_V6.P6.03.EC1512.10.hds
              -System Recovery CLX_9301_9201_EV11.11.14.09_FS11.01.00.00.71.ehd
              -UI Recovery V5.16.00.33.00_2015022623.hd
              Nothing seems to take. How does one get the older firmware being referred to. The firmware that bricks the machine is what is available from HP direct which is Samsung_CLX-92x1_93x1_Series_V6.P6.03.EC1512.10.hds. I have seen a few of the OPE pwb available online but they are far away and pricey. If firmware can solve this issue can someone please provide a link to older version that will restore UI functionality please.
              Thank You
              • Arcadian
                • Feb 2010
                • 218
                #22
                Tried:
                Thank You
                • mhanes@sdwp.com
                  • Jun 2014
                  • 10
                  #23
                  I used a 4GB thumbdrive formatted as FAT32 I can try to look for something smaller but one is fairly modest.
                  • nabruxas
                    • Mar 2024
                    • 2
                    #24
                    I am also seeking for the older Firmware, ie. Rev: V6.O6.09
                    HP is not use/helpful. They provide only the last version that cause the problem.
                    Can somebody share the file?
                    Thx in advance.
                    • mhanes@sdwp.com
                      • Jun 2014
                      • 10
                      #25
                      This link seems to have the file on it towards the bottom:
                      It has now been a while since I performed this update so please refer to my instructions as I found the process very vague and when it did finally work I tried to document.
                      • mhanes@sdwp.com
                        • Jun 2014
                        • 10
                        #26
                        I commented on this in a different post on this topic follow link and the link to files is in there along with detail instructions
                        CLX-9201 bootloop - Copytechnet.com
                        • nabruxas
                          • Mar 2024
                          • 2
                          #27
                          I'm thrilled. THANK YOU VERY MUCH.
                          I had to find a 4GB flash drive with less storage and format it to FAT32.
                          Remove the "UI Recovery" prefix from the filename.
                          Then it worked perfectly.👍
