Samsung xpress C1860FW
  • OlliK1969
    • Nov 2016
    • 311
    Hi
    Order rejected, scanner not available.
    With the device you can print without any problems, when scanning it shows the above on the display, it also starts the scanning process, but 7cm of the original is missing on one side. All plug connections checked.
    Carried out in the technician mode "Shading Test" and the same result, 7 cm missing in all 4 test areas.
    Any ideas ??
  • dalewb74
    • Feb 2018
    • 1157
    Re: Samsung xpress C1860FW
    just me, given the age of the machine i would buy a new one.
