samsung slx-3175fn jam at 1
I forget what jam codes I saw, but I have seen jamming caused by excessive paper dust in the pre-registration sensor. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
The PE sensor and pre-registration sensor are between the cassette and registration roller. I seem to recall accessing the sensor from the rear door. Sorry I can't remember the details. =^..^=If you'd like a serious answer to your request:
I took the printer apart again.
The pre-registration sensor is the mck sensor (small pcb) right?
It was clean, no paper dust.
I also took out and checked the pick up roller, doesn't seem worn at all, still feels "sticky".
I doubt replacing that would help, but I am running out of idea.
Can the paper cassette be at fault?Comment
Only if the cassette length is not set correctly. Sorry, I'm out of ideas.If you'd like a serious answer to your request:
Ricky Jhon
fungku
It's worth the $134.00 to have a professional do the work. If you do it yourself you will risk creating more problems than already exist. The copyboard glass doesn't need to come off, anyway.
I'm here to help professionals do their job better, not drive them out of business.
Please don't take this personally. There is enough information in the original post to do this task. If you want, take a try at it. But I recommend that you use the services of a professional. =^..^=
That's over 50% the cost of the printer. Absolutely not worth that investment...
I'd rather buy a printer that isn't a POS to begin with.
Sorry, I now have to find somewhere to get this part in Vancouver, BC and wait printerless until it comes so I am a little bitter and once loved Samsung now can't stand them.
Cheers...Comment
cgreen6911
Looking for Orginal Post on how to Replace the 0604-001393 Sensor on CLX-3175FN
Forgive me, I have just joined this forum. The information on replacing the sensor for the Samsung CLX -3175FN printer jam issue, perfectly describe my issue.
There was a mention that the original post describes the procedure for replacing the sensor. Can someone point me to that post!
Thanks in advance.
Cgreen6911Comment
It's the exit sensor. The sensors in the original build have the white connector. Part # 0604-001393
Just be careful removing the covers. Right side first, then the scanner, then the left side, then the engine top cover. Then you'll see the sensor (it's next to the fuser, not in the cover).
I can do it in 35 minutes, and I'll bet you can too, after a dozen tries. =^..^=If you'd like a serious answer to your request:
cgreen6911
Samsung CLX3175FN Jam at 1
Blackcat4866,
Thanks you for the quick reply. I have ordered the parts and will replace it using your instructions. I have also purchased the Maintenance manual for the CLX-3175FN. I expect that with these instructions, the repair will go smoothly.
Thanks for the help and for this forum.
Cgreen6911Comment
guinness1772
This sounds like my problem. Stuck at Jam 0 on a 3175FN. Can't seem to locate the PN to replace this part... I will admit I am having trouble finding it so that I can clean the sensor off... More hints please!
I am more than willing to pay a pro to come out and service the printer but they want $250.00 to come out and the printer is only worth $300. I would really like to salvage this printer and not send it to the land fill.
mineme
Hi ... I replaced the 0604-001393 sensor...I took my time and it was not that difficult....BUT it still shoots the Jam 1 error code.
Any thoughts of what it could be...new sensor was bad (from Samsung) or a bad installation? Anything else?
ThanksComment
