How to Execute ECD Program for Samsung CLX-3175FN
  • lebric
    sorry to bother you all but if someone can tell me how to Execute the ECD program for my Samsung CLX-3175FN i would more than just appreciate. I have the service manual but it doesn't tell how to activate EDC it just says Execute EDC Program that s it...please help
    • 23008
    EDC Mode uses a small piece of software on your laptop to communicate via the USB connection to the printer. Earlier levels of firmware allow use of EDC Mode. Later production allows only SmartPanel or Web Interface access.
    Don't overestimate the usefulness of EDC mode. If there is a system error you will not be able to use EDC mode. It's generally not very useful.
    You should have no difficulty finding the EDC software or SmartPanel software. SmartPanel is generally a better diagnostic tool. What sort of problem are you trying to diagnose? I've worked on a lot of the CLP-315/CLP-315W/CLX-3175FN series machines. =^..^=
    • lebric
      Hi Blackcat 4866,
      I have my sensor problem but would like to test all the rest of my sensors so that s why i would really like to have the EDC soft that samsung work with since i got the menu in the service manual but if it is not possible i m willing to try smart panel as you mentionned but got no idea where to get those 2 tools? i m passing and order so i want to test ALL the printer component before passing my order to the electronic store ,thanks again and much appreciate !!!!
      Eric
        • 23008
        EDC won't help with that, neither will SmartPanel. SmartPanel will display "Paper Jam 1". The diagnostic modes for this machine are next to useless. The only way to test out that particular sensor is to meter out the 5vdc output from the exit sensor. You can try to bend a couple of paper clips to use as leads to reach pins #1 & #3 at the sensor or at the HVT connector. Anything over 3.2 vdc is a high reading, anything below 3.0 is a low reading. (Typically ranges from 3.6vdc high to 0.3vdc low)
        Or you could just trust me. I've changed over 75 of these sensors, and have never seen another cause. It is a lot easier to diagnose this problem on a CLP-315 (the printer version). You can pop the top off and pin out the sensor all you like. On the CLX-3175 its considerably harder to get to the pins.
        If you still want the software just google "EDC Samsung" or "Smart Panel Samsung CLX-3175". www.nodevice.com is a good source for most printer related software. =^..^=
        • lebric
          i'm trying to run the appz on my pc (vista 64 bit) but get the write error, error. I guess it is because i got an error on my printer? or because i m using 64bit OS? or because i m stupid ..lol , thanks
            • 23008
            It doesn't matter why. It won't help you test sensors. I hope I haven't mislead you. EDC software will not help diagnose a bad sensor, and may not function at all on later levels of firmware. Please don't waste your time with it. =^..^=
            • lebric
              i'm waiting impatiently for my part to come in
              i removed all panel , left , right and top i see my fuser perfectly but i m wondering where is that ''Exit sensor'' ? i searched all over the web to try to find out a picture of that sensor ...nothing. Also, i ordered the part from Global Electronics ...
              0604-001393 PHOTO-INTERRUPTER 1 $1.61and i hope it is the right thing....
              thank you
                • 23008
                That is the correct item. =^..^=
                • lebric
                  Problem fixed with the help of blackcat 4866
                  • gmenestr
                    SAMSUNG CLX 3175 continuously looping reset
                    After sending some multiple recipient fax, it suddenly froze, once restarted, it keeps looping a restart with following error messages:
                    Warming up
                    FAX SSM...
                    Interna Error
                    and again and again
                    Any suggestion on how to reset it to factory defaults?
                    Thanks, Guido
                      • 23008
                      If it's not booting up properly, you've got two possibilities, and the first one probably won't work.
                      1) Upgrade or reload firmware. If it hasn't completed bootup it won't take firmware.
                      2) Repl PBA main controller.
                      • gmenestr
                        Thanks a lot, blackcat.
                        Where can I dl the firmware to replace? And how do I put it in, via a USB stick or via usb cable and a software?
                        Guido
                          • 23008
                          I have gotten firmware from the Samsung service portal. I'm guessing that you're not a dealer and don't have the proper login.
                          It may be available from the Samsung public site. Do a little Google searching. =^..^=
                          Try this: http://www.nodevice.com/driver/CLX-3.../get50211.html =^..^=
                          • guinness1772
                            CLX-3175 Jam1, now Jam0
                            Blackcat
                            I have a printer that was getting a persistant Jam 1. I replaced the top set of rollers (recommendation by tech support) and now for some reason I am getting Jam0. I downloaded the service manual and it also pointed me towards this EDC software to try to issolate the bad part/sensor. I found this thread (very helpful) but I have a few more questions:
                            1) Any idea what could have happend that would cause my Jam 0 issue by replacing the top set of rollers?
                            2) What can I do to fix the Jam 0 issue. Could you post the PN of the sensor I should be replacing and a link to a tech ref that I will need to replace the sensor(s).
                            Thank you in advance!
                            • JustManuals
                              • Jan 2006
                              • 9838
                              Just Manuals | The Internet's largest selection of manuals | Instant Downloads
                              Paul@justmanuals.com
