Samsung SCX weird problems:
  • Jude
    • Oct 2009
    • 256
    [Misc] Samsung SCX weird problems:
    Not my week for Sammis! I have two seperate accounts, two different weird problems:
    1.) Machine called for toner, customer installed a OEM toner from a sealed box, machine runs on and on then goes to "Ready to Copy" while still running but print key does not respond to any input. Machine will read "no response from MCB" and the go back to ready to copy, Machine only has around 20,000 copies total. I will check the spring in the back any other ideas?
    2.) Second machine is a factory refurb. Loaded print drivers ets and tried to print. Test page and all is well. Customer calls later and says after machine went to power save, the machine would not print until power cycle on and off. I have printer on static IP. Loaded correct drivers. Anyone els eseen this problem?
    • 22999
    OK. I give up.
    What model or models are you referring to? =^..^=
    • CT Copier Repair
      • Mar 2010
      • 304
      blackcat
      it was a Sammi
      and a refurb Sammi
      those are the models
      man i had a long week
      going to piss everyone off sitting here drinking Newcastles
      and to think tomorrow i quit smoking oh happy happy joy joy
        • 22999
        Ah! That's much clearer. Thanks.
        Me? I'm aiming for 7 consecutive hours of sleep. Glorious sleep.
        Zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz =^..^=
        • Jude
          • Oct 2009
          • 256
          sorry. Bad week and I don't drink! Samsung SCX 6555N both machines.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            Haven't had to much weird stuff on the 6555's, but plenty on several other Sammis. No response from MCB means Ram clear first, Firmware second, and you better have the Main Control Board on the way! Also back up your address books before the ram clear. And I've replaced several hard drives in the Sammis.
            Mystic Crystal Revelations
              • 22999
              As to #1, there's a bulletin on this. Like the Sharp Panther series, the plastic shaft of the toner motor breaks, but does not shear off. When there is rotational torque on the motor shaft, the roll pin twists the shaft, binding the spring loaded coupler. I don't know if there is a new style part, but it's the toner motor, for sure. On the Sharp machine, they came out with a toner motor with a metal shaft. =^..^=
              • Jude
                • Oct 2009
                • 256
                Blackcat: Could you please provide for me a part number or assembly breakdown? I have the ma nual and am wondering if it is part of the maindrive assembly?
                  • 22999
                  It looks as though you have to order the whole drive assy (JC97-02681A).
                  It does not look as though this is an updated part. You may expect re-occurrences.
                  • Jude
                    • Oct 2009
                    • 256
                    Thank you BC!!
                    • Canuck
                      Tech Specialist
                      • 1713
                      Re: Samsung SCX weird problems:
                      Toner coupling...JC97-02681A.......changed many. "no response from MCB"...install a NTFS formatted hard drive..changed a few
