Problem tech menu
  • hmac
    • Aug 2009
    • 129
    Problem tech menu
    I have a 3175 and I can not go back into the menu technician.
    I tried the following combinations without success:
    Menu # 1934 # Stop
    Menu # 1934 OK Menu
    Menu # 1934 # OK Menu
    Menu Menu # 1934
    Menu # 1934 Stop
    Menu # 1934 OK Menu
    Is to reset the drum counter to zero.
    What is the procedure to follow to enter the menu technician?
    Or how to reset the machine to factory setting?
    _________________
    HMac.
    _________________
  • hmac
    • Aug 2009
    • 129
    I try on another CLX3175 the menu technician:
    Menu # 1934 is that good.
    How come back in the menu on my 3175 because its not working.
    I have to recalibrate the colors or put the factory settings.
    thank you
    _________________
    HMac.
    _________________
      • 22932
      I've been working on Samsung for over two years, and this is the first one that needed a drum replacement. It turns out that the drum times out at 24K clicks, 4 clicks per color, 1 click per B&W.
      So my customer buys a drum unit, reads the directions, and installs the Imaging Unit. So far so good ... except for the fact that the "Replace Imaging Unit" message is still there.
      Two hours of searching to find this in the Service Manual:
      Press: Menu, #1934, Menu, "Tech Mode <Tech Mode>" OK, "Data Setup" OK, > x7 to "Clear Counts" OK, "Enter Password [????]", 1934, OK, "Clear Counts [Total Page CNT]", >x3 to "[Imaging Unit]" OK, "Clearing…", back.
      It just doesn't make any sense to me for the manufacturer to sell an imaging unit as a user replaceable supply, but does not include the reset procedure with the drum unit, or in the users manual. And the procedure in the service manual is nearly incomprehensible.
      • hmac
        • Aug 2009
        • 129
        I know the procedure to reset the drum counter.
        The problem is that when I do: Menu # 1934 its not working.
        I can not go back into the menu technician. : x
        I also have a problem with colors. Because when I make a color copy, the image is repeated several times on paper. I is not the problem in N / B.
        I try to change the following part:
        - drum
        - Transfer Belt
        - all cartridges
        I would like to know how to calibrate the colors and also how to reset all factory settings.
        _________________
        HMac.
        _________________
          • 22932
          Menu # 1934 # Stop
          Menu # 1934 OK Menu
          Menu Menu # 1934
          Menu # 1934 Stop
          Menu # 1934 OK Menu ...
          I don't see Menu, #1934, Menu
          anywhere in this list. Did you try it? =^..^=
          • hmac
            • Aug 2009
            • 129
            I have try but is not work :x
            _________________
            HMac.
            _________________
