Samsung ML 2551N Laser Duplex Printer
  • tech9
    • 216
    Printer does not boot . there is power as the display shows a faint squares on display. when you switch off you see motor slightly move ?
  • gordie
    • May 2008
    • 83
    Hi I could be wrong but I would suspect a power supply problem.
    Regards Gordie
    sigpic
    • tech9
      • 216
      i was thinking the same, i have heard this box is the same as a xerox 3450dn.
      so i take it the power supplies are interchangeable
      • JustManuals
        • Jan 2006
        • 9838
        Just Manuals | The Internet's largest selection of manuals | Instant Downloads
        Paul@justmanuals.com
        • Masterchief
          • Apr 2011
          • 280
          I also belive it to be power board failure, check the contact points on the board with your meter for correct voltage etc!!!! just to be certain...
          Masterchief
          sigpic
            • 23002
            We had one that used two power supplies within 6 months. The customer turned down the second one. =^..^=
