Samsung SCX 4600
  • laki1234
    • 6
    [Electrical] Samsung SCX 4600
    I need service manual for Samsung SCX 4600,
    I have a problem that I occasionally released white paper.
    thanks
  • JustManuals
    • Jan 2006
    • 9838
    Re: Samsung SCX 4600
    Paul@justmanuals.com
      • 22997
      You want a manual, I get that part. But why? White paper? =^..^=
      • laki1234
        • 6
        I send something from a PC to print, the printer comes out white paper.
        The same happens when copied.
        I need a service book to see through troubleshooting, and if there is a scheme
        high voltage plate. I think that there is no voltage on the drum.
        • Blizzoo
          • Aug 2013
          • 607
          Check the drum grounding contact plate,maybe is bent and not making contact well.You could try an hard stop to see if is image formation on the drum.
          Easiest way for troubleshoot is to test with another good cartridge
