SCX-5935 A4
    • 14723
    SCX-5935 A4
    I have a customer with a Samsung SCX-5935 and everything that comes in, either from fax or print, wants to go on A4 instead of letter. I have made sure the paper trays are set correctly, but, it errors and asks for A4 paper to be loaded.
    I have checked all the settings that I know of to try to fix this problem.
    Does anyone have any insight into this issue?
    Any info is appreciated. Thanks
  • tseto
    • Jun 2007
    • 60
    Re: SCX-5935 A4
    Your customer probably corresponds with people from hk or Europe where their documents are on A4 instead of letter, the easiest solution is to sell them a second tray and set that tray as A4 and the machine will select the correct tray as demanded by the document.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Re: SCX-5935 A4
      It's been a while since I've seen one of these fine POS's, Don't they have a setting for paper size substitution?? If so set it to sub A4 to letter. Back in the day of faxes it was common to see on the display of a fax that it was sending A4->A4............ the receiver would print on letter though........
      Mystic Crystal Revelations
        • 23008
        Re: SCX-5935 A4
        I have looked for the Auto A4 function on previous Samsung's and it just wasn't available. tseto has the only practical solution. =^..^=
        • Tonerbomb
          • Feb 2005
          • 2589
          Re: SCX-5935 A4
          That may very well be the case, But what about frimwar?? I know sammy rolls out new versions often for these.........................
            • 23008
            Re: SCX-5935 A4
            I've thought of a second choice:
            In the print driver default paper selection to Tray #1 (not Auto)
            In the print driver default to Fit-To-Page.
            The first choice ensures that the page will print regardless of original size. The second choice ensures that the image will fit the paper size.
            That solves prints only. It won't do a thing for faxes.
            Perhaps you could forward faxes to email, then print them via the print driver? I know it's a bit circuitous, but it gets you to the right destination.
              • 14723
              Re: SCX-5935 A4
              Sorry guys. I forgot to post that I had solved this. I ended up restoring defaults and setting paper trays up again.
              Thanks for all the responses.
                • 23008
                Re: SCX-5935 A4
                I'm sorry. I don't understand the resolution. Were you able to dedicate a tray to A4 paper size? =^..^=
                  • 14723
                  Re: SCX-5935 A4
                  I was able to dedicate a tray to letter size.
                    • 23008
                    Re: SCX-5935 A4
                    If you're in Desboro ON, your pretty close geographically. Congratulations.
                      • 14723
                      Re: SCX-5935 A4
                      According to Google maps it is just 352km. Not far at all.
