Samsung SCX 6345 jams
  • jockey
    • Aug 2008
    • 52
    I have a SCX 6345 that will run a job fine then jam everytime on the next, I'm a Kyocera guy and have never worked on Samsung, I replaced the feed tires in both trays hopeing that was the cause, the copy stops just before it exits the machine, no fan folding it just stops leading me to believe it's a switch or sensor.
  • arnh79
    • 468
    Re: Samsung SCX 6345 jams
    Failing exit sensor is pretty common on these. The heat damages them. Sounds like that's your problem.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
      • 22997
      If you knew what the jam code was you could confirm it. =^..^=
      • webauk
        • Jun 2014
        • 9
        I have had the same on a samsung scx 4216f I striped it blew dust and voila, but then bumped into another problem
        • jockey
          • Aug 2008
          • 52
          Thanks guys, it turned out to be the exit sensor.
