MX C300
  • CrapAimer
    • 296
    MX C300
    Has anyone had trouble with the fax unit on these, i have one which is sending no problem but wont receive, machine ringing but not answering, machine just out of box
    George
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: MX C300
    George
    I had this symptom when I mistakenly installed the memory card in the wrong slot.
    • ntbann
      • Jan 2012
      • 626
      Re: MX C300
      Are you sure that it is plugged into line not phone and is this on a voip?
        • 22996
        Re: MX C300
        You would get this same result if it were set to distinctive ring setting. There's no particular reason for it to be that way on setup though.
        Did you select the correct country code? Maybe that would do it. =^..^=
        • Disl
          • Dec 2012
          • 2
          Re: MX C300
          I had this problem with a MXC301W yesterday. The machine had been faxing fine but suddenly stopped receiving, just ringing out. A full restart of the machine solved it for us. We also applied the latest firmware as there was a fix for a fax issue in the latest firmware.
          • tr210907
            • Jul 2011
            • 40
            Re: MX C300
            Had this issue before also and one thing that helps is to ensure that phkbe line is a two wire like one that ships with machine and not a 4 wire line
            • drowranger
              • Jul 2015
              • 122
              Re: MX C300
              with this model make sure it has latest firmware currently ( 0206E100 )
              then Confirm if the fax destination is set correctly.
              you can disable ecm using sim 66-1 switch 17 bit 8 to 0 and increase signal sending out level in sim 66-1 switch 25 bit 4 to 0 that might fix the problem.
              there are few more fax soft switches we can play with. good luck !!
                • 22996
                Re: MX C300
                I have it on good authority that firmware is a major source of fax problems on these machines. Definitely upgrade the firmware. =^..^=
                • CrapAimer
                  • 296
                  Re: MX C300
                  i have downloaded this firmware is the right one NEOMFP_MAIN_0206E100_WT.sfu
                  george
                  • Alpanapa
                    • 20
                    Re: MX C300
                    I dont want to be that guy, buuut...
                    Have you checked if the machine is on auto answer and not manuel answering?
                    I had one customer with that problem, brand new och not receiving fax, and the problem was that it was on manuel answering.
