Sharp MXB401 Almost Blank Copies
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [CQ] Sharp MXB401 Almost Blank Copies
    We have a Sharp MXB401 in the field that we replaced the Developer Unit, Drum Unit and Fusing Unit in 3 months ago and everything has been fine until Friday. It is producing almost completely {BLANK - edited,oops} copies/prints (including the self test/list, simulation 22-06-01). Only a very faint image appears on one edge. I swapped the Fusing Unit, Developer Unit and Secondary Transfer Roller in the right door with NO CHANGE. I inspected the the Primary Transfer Belt and the Drum unit and everything appears to be fine except for some clicking {I CAN FEEL WHEN TURNING DRUM BY HAND - edited} in the drum unit, however it will turn past it in both directions. Also checked the High/Low Voltages with simulation 08-.... and ran the LSU Test, all passed. ANY IDEAS? Help, Thanks in advance!
    It does not matter how slowly you go as long as you do not stop. –Confucius
    • 23008
    Re: Sharp MXB401 Almost Blank Copies
    My bet is that clicking you're hearing is the primary charge, discharging to the drum. That also explains the black copies. =^..^=
    • MFPs R Now PCs
      • Jul 2011
      • 156
      Ooops,
      Did I say Black Copies, they are Almost Completely Blank, and the clicking is what I feel when turning the drum...?
        • 23008
        Well that changes things a lot.
        What happens if you remove the primary charge? It should go completely black. If it doesn't you've ruled out charge as the issue.
        I'm wondering if you might be losing drive to the developing unit? =^..^=
        • drowranger
          • Jul 2015
          • 122
          this seems to be an arcing mc grid. run a sim 25-1 and check the value. better change or swap the drum unit and see what happens.
          • spanky
            • Sep 2012
            • 468
            Stop the machine during the copy cycle to see if the image is right on the drum or the transfer belt.
            If image is right on the drum and not the transfer belt you have a problem with in the primary transfer with the roller that brings the belt down to the drum.
            If the image is bad on the drum you could have a problem with the shudder on the LSU not opening properly.
            • mojorolla
              The Wolf
              • 2622
              These units are notorious for the IT belt cam collars shattering on one side. These parts are all plastic and come with the frame, no repair possible. You will need the entire belt unit.
              • mojorolla
                The Wolf
                • 2622
                odd, editing is not working..... Turn the cam by hand and look at the 1st transfer roller inside the belt unit, it will drop down towards the drum. If only one side of the roll drops down, the cam is shattered.
