Plastic Cellophane looking substance around fuser-in middle of job
  • rightbrained
    • Oct 2014
    • 40
    [Misc] Plastic Cellophane looking substance around fuser-in middle of job
    I am running a long job on my Sharp MX-2700N.
    I am using digital gloss paper.
    After a jam, I noticed what appears to be cellophane wrapped several times around my fuser roller (the hot one).
    Is this from the paper or the long job? Is the "cellophane" part of the roller and should be smoothed out as best as possible with a soft rag or is it foreign and should be removed after machine has cooled?
  • rightbrained
    • Oct 2014
    • 40
    Re: Plastic Cellophane looking substance around fuser-in middle of job
    fuser.jpg A picture is worth a thousand words.
    • tr210907
      • Jul 2011
      • 40
      Originally posted by rightbrained
      [ATTACH=CONFIG]30454[/ATTACH] A picture is worth a thousand words.
      That there is actually part of roller had one look just like it.. It would still perform but we went and replaced with new MX 270FU1 rebuild would be more costly
        • 22999
        Yes, that "cellophane" is part of the pressure roller that has separated. Once it starts wrinkling, it will give your copies an interesting texture and sometimes not fusing in the wrinkles.
        Though it seems intuitive to trim off that sleeve, it doesn't work out well. The teflon sleeve prevents the toner from sticking to the roller, so what does it do? It sticks, and reprints on your images. =^..^=
        • drowranger
          • Jul 2015
          • 122
          if theres no flat spots on the upper heat roller and looking good ,
          then just replace with the mx270lh or the spare part version. this always happens with the roller fusers over time.
          • leong.supertroni
            • Aug 2015
            • 13
            Time to replace the lower heat roller. Can fix within 15minutes
            Sent from my GT-N7000 using Tapatalk
