Sharp ARM257
  • Tech2002
    • Aug 2008
    • 334
    Sharp ARM257
    Have an issue where copies, just along top lead edge where it has streaked copy.
    Have changed the Drum, Blade, DV, Toner blade, Updated Fuser, and every time
    I leave account everything is fine - then I get a call a week later telling me the issue
    is back again.
    Any suggestions welcomed!
  • faxman28
    • 436
    Re: Sharp ARM257
    is back again.
    sample image would be good, one mans streak is another mans smear. have you replaced DV seal or are you calling it toner blade, also the main charge can cause streaks. the seal on the drum unit wears out and the drum unit needs to be replaced.
    • walterman
      • 196
      Re: Sharp ARM257
      A sample of the issue would be helpful. Is the customer having the issue out of tray 1 or the bypass tray, etc. Is it happening first thing in the morning, is it happening during large runs?
      • Tech2002
        • Aug 2008
        • 334
        Re: Sharp ARM257
        Sometimes the simplest replacements are the easiest to overlook. The DV Blade looked fine, however, when changed - so far, things are good. Thanks for showing me something I should not have overlooked.
        • NeoMatrix
          Senior Tech.
          • 3514
          Re: Sharp ARM257
          Did you replace the fuser hot roller cleaning felt ?
          Did you fix it firmly into place correctly ? They're fuser pad is only good for 150k.
          I can't remember it this model has a similar toner compacting fault in the dev unit like the ar155's.
          Fault: The toner packs firm into the dev unit and creates void streaks on the copies.
          Solution : Vaccum out half the toner out of the dev unit and replace it.
          HTH
          ------------update ---------------
          For the apprentices out there. DO NOT vacuum the toner out of any "dual component" developer unit regardless of the machine make or model.
          You can only do this with a mono developer unit systems.
          • Tech2002
            • Aug 2008
            • 334
            Re: Sharp ARM257
            HTH
            I didn't mention that in the original quote - but yes, I did all of those things - it was the DV Blade that was the culprit. I've never missed this in 20-years. I thought because the way things evolved it was electronic and not something simple. Thank you for responding. I'm going to stand in the corner and feel stupid for awhile.
              • 22993
              Re: Sharp ARM257
              HTH
              This is dual component developing Neo. I would hate to see what happens when you vacuum out half of the developer. It would overtone like crazy. =^..^=
              • ZOOTECH
                Senior member of CRS
                • 3375
                Re: Sharp ARM257
                ... Thank you for responding. I'm going to stand in the corner and feel stupid for awhile.
                No need for that, if everyone 'fessed up, you would have lots of company in that corner.
                • Tech2002
                  • Aug 2008
                  • 334
                  Re: Sharp ARM257
                  Never own up to a mistake to appear you're not as smart as the guy that screws up everything and blames it on the Customer. If it was understood, the mylar looked good. Have a good night.
