Sharp MX-2600 scanning very slow
  • lenovos
    • Oct 2012
    • 141
    I bought an off lease Sharp MX-2600. We set up scan to folder in our office. The problem was that the copier scanned very slow,like two minutes from start to finish. The scans did eventually get to the folder. We checked compression and all the usual stuff, I decided that maybe it was a windows 10 issue until I delivered the copier and had the same problem on the customers windows 7 PC. As a last ditch effort I scrolled through the network settings on the control panel and tried a reset the nic. What ever was wrong it solved the problem. We did have to add the IP address but now it works great. Hope this helps someone.
  • drowranger
    • Jul 2015
    • 122
    Re: Sharp MX-2600 scanning very slow
    its always good to run a sim 67-17 , 66-10 , 62-1, delete job log and nic card reset for used machines. Dont forget there is a new firmware for rendering issue fix for this model.
    • Toner Boy
      • Aug 2007
      • 366
      Disable mDNS and try again
      • igi
        • 1507
        Hi scan to Usb stick.
        eliminate the network to test.
        • ntbann
          • Jan 2012
          • 631
          Did you test to see if is scans slow with a cross over and a laptop?
