Sharp AL 1631, Light on lead edge
  • james
    • Jul 2008
    • 21
    Replaced with new O.E.M. drum, toner/dv, changed t/s charge in door, cleaned laser glass above drum. Any thoughts?
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    Is the issue the same off the glass as through the document feeder? If it is only from the document feeder then I would suspect that ambient light is causing the light leading edge.
      • 23010
      Are you using OEM toner? =^..^=
      • james
        • Jul 2008
        • 21
        Yes, OEM toner and drum.
        • aeroinc
          James,
          I am not personaly aquanted with your particular model copier. But did not see you mention cleaning the mirrors most units use a series of mirrrors to reflect the image thru the magnification lense. If this is the case clean all mirrors infront of the lense and behind the lense. If this is not the case please ignore the post.
          P.S Many digital units use a laser to write and the mirror attached to the mirror motor may need cleaning. One edge that cuts the air will gather excess dust and cause light print. Have experienced this on printer and fax machines as well. Good luck
          aeroinc
