Sharp MX 3100 No power
  • NeoMatrix
    Senior Tech.
    • 3514
    Re: Sharp MX 3100 No power
    Originally posted by Doug James
    Can you believe the customer had 220V running into the 110V outlet... Holy Crap... I am ordering another AC and DC power supply and going from there... Just hope the fuses prevented damage to the rest of the machine ...
    I'm a tad confused ?... (de'ja' vu)
    I always thought the domestic USA power grid was 110v.
    Does the USA "domestic" power grid have dual 110 and 220 voltage single phase systems ?
    Do you guys have two different voltage power points wired into your homes or offices ?
    How does a 110v photocopier get plugged into a 220v power point ?
    Here in OZ we have only one domestic source of 240v single phase into all homes and offices.
    All medium to heavy industry voltage source steps up from there with 415v 3 phase.
    You can not plug anything by accident into 415v because the plug an socket is the size of a can of Coke, with a 4 pin male an female key-way socket.
    Interesting how that happened.....
    • harleyrider
      • Oct 2011
      • 348
      Yes we do have 2 incomeing 110 line to our homes.Here in the states we have both 110 and 220 volt lines. 110 is for basic things (copiers-tvs-etc.) 220 volt is used for heavier needs (air conditioners ,bigger copiers, dryers etc.) 220 is just a 2 pole breaker with 2 110 volt lines leading to the outlet. There are many different amps. That is a very basic description but that is what we use.
      • Motormount
        • Sep 2010
        • 78
        I was going to suggest that you check the outlet with a VOM to look for that, but I thought it was too remote a possibility.
        I had a client install a dedicated outlet for a Sharp SF-741 (I'm dating myself here), and call me because the fans were running loud. Everything else worked. I found 208VAC at the outlet. They called the electrician and put him on the phone with me; he said "Oh, oh, I know what I did wrong!" like it was a quiz or something.
        After he straightens out the wiring, they plug the machine in, and everything is back to normal.
        They don't build them like that anymore.
        • ZOOTECH
          Senior member of CRS
          • 3375
          #19
          I am surprised that someone that doesn't know what they are doing, didn't fry themselves when making the connections (must have at least turned the breaker off?).
            • 22997
            #20
            I do believe it. On new setups I always check the outlet. I found a 220V 20A wired in a most interesting way:
            120V hot1 to neutral
            120V hot2 to neutral
            0V hot1 to hot2
            Both hot leads were off the same leg of the breaker box. Sorry, that's not 220VAC.
            Good luck. =^..^=
