Sharp AR-287 scan unit jamming
  • stimpy
    Sometimes the scan unit isn't moving to the end and remains
    at one position, then goes back and works fine for the next
    20 or 30 copies. No error code is shown, The whole copy
    process is not interrupted
    Out of 50 copies only one or two are not correctly scanned.
    http://www.wetter-bilder.de/images/ScanImage001.jpg
    Has anyone run into this issue?
    Any help would be greatly appreciated.
  • DavePo
    • Jul 2008
    • 305
    Sounds like the scan motor is failing. You would need to detirmine if it is a 2 phase or 3 phase motor. Then if its 2 phase it will need to be changed to 3 phase along with the scan pwb and bracket. Another possibility is the bearings in the pulleys of the scanner units going bad.
    • paul bristol uk
      • Nov 2005
      • 51
      My money is on scan motor, seen it enough over the years but it costs nothing to check pulleys and bearings.
      • stimpy
        Thank you for your fast help!!
        I'm trying to get a new scan motor.
        I guess it's the least expensive option.
        Kind regards
        • lobbelios
          • Oct 2008
          • 5
          My guess would be the scanner drive pwb.
          • NCArt
            Mountain Tech
            • May 2008
            • 81
            I ran into this on a AR 337....never could get it to work, even after changing the scanner motor, drive cables, scanner assembly friction pads. Good luck, I'll be interested to see what fixes your problem.
              • 23006
              I agree with lobbelios. I've seen quite a number to the 2-phase motor driver PCBs go bad. And only one or two of the two phase motors (large brass flywheel).
              I usually don't worry too much about upgrading to the three phase motor (no flywheel) if I have a good scrap two phase motor. But if you decide to do the upgrade, run simulation 26-59 to change from 2 to 3 (phase).
              • mrfixit
                Senior Technician
                • Sep 2007
                • 83
                This is vert common, if the pulleys are good i usaully do the motor and board together, i'd rather absorb the cost then screw around and drag it out.
