MX-M264
  • Masokisti
    [Dead] MX-M264
    Hi, We have a sharp mx-m264 thats been in the customers office for a little over 2 months. Got a call today that the touch screen was unresponsive, and upon arrival shut it down unplugged from wall, booted back up and it was working. went to simulation 65-1 to calibrate the touch screen and it froze upon cancelling simulation, tried to boot back up several times. The scanner moves slightly after flipping the switch and the energy saver light consistently blinks. I personally think it is the power supply but i would like a second opinion, Thank you for your time!!!
  • harleyrider
    • Oct 2011
    • 348
    Re: MX-M264
    any fix as I have a one doing almost the same?
    • SwisSeV
      • Jan 2016
      • 307
      Re: MX-M264
      Was the DC PSU ever replaced? The factory PSU was known to fail.
      • harleyrider
        • Oct 2011
        • 348
        Re: MX-M264
        The fix on mine was remove the fax option. Had a fax option installed but was not used-no phone line . Had been working fine . Weird
        • hellcat
          • Jan 2012
          • 126
          Re: MX-M264
          We had a similar issue on a ARM257 the older gen of this machine. Came out to be the low voltage board.
          • chubblies
            • Jun 2011
            • 155
            Re: MX-M264
            If the mc does NOT have the hard drive kit fitted, replace the SD card. They fail frequently on non-hdd machines
            • harleyrider
              • Oct 2011
              • 348
              Re: MX-M264
              there is no hard drive or sd card on mx-m264
              • chubblies
                • Jun 2011
                • 155
                Re: MX-M264
                There is an SD card definitely, and you can fit an optional hdd kit. If you do not have the hdd kit, the SD card is used to temporarily store scan and copy data as well as the boot OS and because of heavy read/write use, it fails... frequently
                • harleyrider
                  • Oct 2011
                  • 348
                  Re: MX-M264
                  can you point it to me in the manual?
                  • chubblies
                    • Jun 2011
                    • 155
                    Re: MX-M264
                    Sure
                    • harleyrider
                      • Oct 2011
                      • 348
                      Re: MX-M264
                      My bad the machine I was having problems with was a MX-M260 not a 264. Too many f***** models to remember.
