Sharp mxc402b
  • 1stcavvet
    • Apr 2015
    • 231
    [CQ] Sharp mxc402b
    I had a problem with this machine 2 months ago. Got a call there was no cyan printing. When I got there The cyan developer was missing, unit was empty. Replaced the unit and the developer, calabrated and that lasted 2 months. now I get faint cyan print if any. checked the developer, still have developer in the unit, but no cyan print, or very very faint. ANY IDEAS? Thank you
    • 23008
    Re: Sharp mxc402b
    Developer dumping is usually a symptom of charge arcing. On the medium to small Sharps it's good policy to change scorotron, grid, drum and developer, when you see developer has dumped. =^..^=
    • 1stcavvet
      • Apr 2015
      • 231
      Re: Sharp mxc402b
      I swapped drums in side the machine the light cyan problem stayed the way it was, I think the dv unit isn't turning(motor or clutch) or power or ground to the dv unit is faulty.
        • 23008
        Re: Sharp mxc402b
        If the cyan developer is depleted again, it won't help to swap drums.
        You do what you think is right. =^..^=
        • 1stcavvet
          • Apr 2015
          • 231
          Re: Sharp mxc402b
          ok, The developer unit is not depleted, it was 2 months ago, at that time I replaced the unit with new developer and calibrated and boom it made a great copy. Wind ahead 2 months I go out there a couple of days ago and no blue I do a single color copy in cyan and it is the palest it could be and be some cyan on the paper. I swapped the drums and the copy looked the same. Got to be some failure in the DV unit ????? now that I'm saying it out loud I think it could be some transfer failure in the ITB???? Well anyway I was hoping someone had a similar problem and Could me some for instance I could look at next. THANKS
            • 23008
            Re: Sharp mxc402b
            So the cyan developer could not possibly dump twice in two months? It might be a good idea to look before going any further. =^..^=
            • 1stcavvet
              • Apr 2015
              • 231
              Re: Sharp mxc402b
              The developer did not dump a second time , it all looks good. It just doesn't print good for some reason. way too light on the copy
              • ntbann
                • Jan 2012
                • 628
                Re: Sharp mxc402b
                Is there a image on the drum? It could be the transfer roller for cyan in the primary transfer belt got knocked out of place. But like Black Cat said when we get a DV dump on any sharp we change the drum, corona kit if applicable, and developer. On that machine you can only get the drum as a unit. That's where I would start!
                • 1stcavvet
                  • Apr 2015
                  • 231
                  Re: Sharp mxc402b
                  going back to check the
                  going back to check the ITB, is there a sim code to check the dv drive with the door open, cheated? thanks
                  • ZOOTECH
                    Senior member of CRS
                    • 3375
                    Re: Sharp mxc402b
                    Yes, to check DV drive, run sim 25-1 with the toners removed - the values should vary slightly.
                    To check the primary transfer, run sim 6 (not sure of sub) - should sequence through 'free', 'black', and 'color'. Cheat the front door, you should see the cam rotate.
                    I agree with the above post that the cyan belt charge roller is loose or the grounding spring is not positioned correctly.
                      • 23008
                      Re: Sharp mxc402b
                      I seem to recall a new transfer belt that had one of the charge rollers fall out before it even came out of the box. I don't remember the symptom though. =^..^=
                      • auburntechnology
                        • Feb 2013
                        • 20
                        Re: Sharp mxc402b
                        hello
                        we have an mxc402sc doing the same thing
                        depleted all deveolper thanksgiving in cyan development unit only
                        no codes
                        now they call back stating light cyan again
                        swapped drums, still no cyan image
                        did you get this resolved?
                        paul
                        • Akitu
                          Legendary Frost Spec Tech
                          • Oct 2010
                          • 2595
                          Re: Sharp mxc402b
                          Typically it will not calibrate and lead to errors "Sub Cyan xx front/rear".
                          • 1stcavvet
                            • Apr 2015
                            • 231
                            Re: Sharp mxc402b
                            No, not yet I'm going back to check the ITB I don't see that there is any other thing wrong , I'm hoping that is the problem.
                            • auburntechnology
                              • Feb 2013
                              • 20
                              Re: Sharp mxc402b
                              no errors for developer failure or itb
