SharpDesk issue
  • Madnhain
    • Dec 2012
    • 148
    SharpDesk issue
    Good afternoon!
    Hopefully this is an easy question:
    on an MX-4100n, customer can scan to email, scan to usb but cannot scan to sharpdesk.
    the message "Scanner in PC Mode" comes up
    I am in a different state and am remoting in. I've updated firmware, had the customer replace the network cable, reinstalled SharpDesk... really hoping it's not the NIC Card, though not sure it would be since I can access the web interface.
    Any ideas on this?
    Thanks!
    *edit* there was a mention of a CE-00 error code from the customer...
  • ntbann
    • Jan 2012
    • 628
    Re: SharpDesk issue
    Default tab in image send set to pc scan. Go into system settings, key operator, image send and disable pc scan. PC scan is for twain scanning.
    • Madnhain
      • Dec 2012
      • 148
      Re: SharpDesk issue
      Sounds plausible. I've got a remote session scheduled for tomorrow. I'll update with status.
      Thank you!
      • Madnhain
        • Dec 2012
        • 148
        Re: SharpDesk issue
        No sir, same issue. Tried restoring to factory defaults. No luck. Sending a technician out to try on his computer.
        • Madnhain
          • Dec 2012
          • 148
          Re: SharpDesk issue
          Tech laptop has same error. Factory defaults did not resolve the problem either. Using SharpDesk "Aquire" I can scan... Something just isn't adding up.
          Any more thoughts?
          Thanks!
          • ZOOTECH
            Senior member of CRS
            • 3375
            Re: SharpDesk issue
            Any more thoughts?
            Thanks!
            Was the GDI version of Sharpdesk installed?
            • Madnhain
              • Dec 2012
              • 148
              Re: SharpDesk issue
              Sorry, you lost me on that one. GDI Version?
              installed SD 3.3, same install package I've used hundreds of times previously.
              • ZOOTECH
                • 3375
                Re: SharpDesk issue
                "SharpDesk GDI (host-based) software 3.2.0.516
                This version of SharpDesk is intended for GDI (host-based) connection only and doesn't support the Network Scan Tool."
                SD 3.3 v1.80 is the latest, but I remember seeing that 3.5 was going to replace it, but I have not seen it on IDNC.
                • Madnhain
                  • Dec 2012
                  • 148
                  Re: SharpDesk issue
                  I haven't looked in a while, you inspired me to do so... I've got a copy that works and don't typically go looking for updates, The current version on IDNC is:
                  Sharpdesk v3.5
                  Day Posted: 2/9/2016
                  However, if I recall correctly, you cannot install this without a hard copy (CD)
                  • PrintToPDF
                    • Oct 2015
                    • 27
                    Re: SharpDesk issue
                    I was unable to install 3.4 without cd.
                    When installing 3.5 mentioned above, the install procedures asks for a product key from dse-pub.sharrp.co.jp. I have been installing 3.3 and running 3.5 as an update. Use instrucitons per TT-012516_7 to retain serial number.
                    • Madnhain
                      • Dec 2012
                      • 148
                      Re: SharpDesk issue
                      I don't think that will resolve my current issue though... seems to be an issue on the copier side.
                      • mbcruzin
                        • Aug 2013
                        • 142
                        Re: SharpDesk issue
                        Not to run off topic.
                        I have been using the 3.3 version as well. I tried a clean install of the new 3.5 but ran into the product key needed issue. If i reinstall 3.3 with one of the older codes that I have memorized then update to 3.5 will sharp catch on too what I've done?
                        • PrintToPDF
                          • Oct 2015
                          • 27
                          Re: SharpDesk issue
                          Not sure what Sharps intentions are, but as of now update from 3.3 to 3.5 is possible.
                          Do not uninstall previous version. Run the 3.5 installer until 'remove previous version' dialog pops up, cancel. This will retain the key. Uninstall 3.3, and rerun 3.5.
                          • Madnhain
                            • Dec 2012
                            • 148
                            Re: SharpDesk issue
                            3.3 can be installed as many times as you like using the same s/n and they're loosing potential sales because people caught on to this I think... just my opinion though.
                            • DavePo
                              • 305
                              Re: SharpDesk issue
                              I agree completely, I believe also that Sharp sees this as a large loss of revenue. Cant tell you how many times customers have bought new machines and added the new license to their existing license list.
