Sharp copiers service serial connector
  • SwisSeV
    • Jan 2016
    • 307
    #16
    Re: Sharp copiers service serial connector
    Originally posted by Jaws
    Resetting the count is your business, but when you try to make the chip work in a different machine its Sharp business. They don't want you to move options (PS3 EXPANSION KIT
    BARCODE FONT KIT
    INTERNET FAX EXPANSION KIT
    APPLICATION INTEGRATION MODULE
    ) that you would have to pay for to another machine.
    Agreed. I haven't spent much time with this mode. I'm sure there are protections to keep people from abusing it like you say and that's probably why Silviu is running into those trouble codes.
    • Silviu
      • Jan 2016
      • 17
      #17
      This special mode you speak of will not let you change data in the e-prom. Use the original eprom that came with machine.
      First of all thank you for your advice, second I have already tried that, I have read already the eeprom information, but seem that I have no use for it because it is a hex/binary code in order to get further with my work I have to get all that information a flash file, and to be honest it dose not worth my time to be invested so much in reverse engineering
      • Silviu
        • Jan 2016
        • 17
        #18
        BARCODE FONT KIT
        I am not interested in resetting the count that won`t help me at all, and is not a problem about options , anyway it was mostly an engineer, deep digging, thank you .
        • Silviu
          • Jan 2016
          • 17
          #19
          Originally posted by SwisSeV
          What makes you say that?
          Granted I haven't done it on the models he was specifically asking about. That being said we have reset the counts in the eeprom in models like the MXM350.
          Again is not a matter of resetting counters , is more a matter o relay on a machine , so let`s say for instance you will have a dead eeprom on a machine to get new one from sharp it can take you up to 4 wks to get it programmed in japan and sent to you
          • lky1978
            • Mar 2009
            • 482
            #20
            u2-30, mfp eeprom serial no. not match with pcu serial no. u already alter the eeprom info.
