Sharp copiers service serial connector
  • Silviu
    • Jan 2016
    • 17
    Hi techs I wonder is anyone has any information about serial comm out of the mfp pwb called service port in the service manual is there any software that would help to get in to mfp PWB , any information would be welcome
  • SwisSeV
    • Jan 2016
    • 307
    Re: Sharp copiers service serial connector
    I'm curious what you are trying to accomplish. What model(s) are you working with?
    • Silviu
      • Jan 2016
      • 17
      I try to gain access to extended service "mode" where you can adjust more than you adjust in sim mode, for instance cannon, xerox allow more access for a tech, `I am working with range MX
        • 22997
        You still did not mention models. Typically that serial port serves no purpose in the field. Personally I believe that it's used by the manufacturer to preload firmware or other data, but that software won't be available to any of us. Like the parallel port on many of the older Canons. =^..^=
        • SwisSeV
          • Jan 2016
          • 307
          There is a mode called special sim, or service sim mode for deeper adjustments. We had to call sharp to get it, they don't put it in the manuals because you can reset some serial numbers and counts and other such things. If a morally questionable customer got a hold of that, they could really rip off their service provider. I used to have it but we forgot what piece of scrap paper it was put on. It's so rarely used by us techs. You can probably find it buried online somewhere or just call the sharp hotline.
          Hope this info is helped you.
          • Silviu
            • Jan 2016
            • 17
            My purpose is to alterate eeprom info in order to prevent u2 30 limist is your imagination , dsk removal would be more convenient, i have cloned the eeprom but i still get the u2-30 so ... that would help i have tried even watermark update
            • SwisSeV
              • Jan 2016
              • 307
              Do you realize you're posting?
              Try the edit feature.
              • Silviu
                • Jan 2016
                • 17
                I do know about dip sim but sharp uk dose not provide that ...
                • Silviu
                  • Jan 2016
                  • 17
                  MX4140, 2600 ,5141 ...
                  • Silviu
                    • Jan 2016
                    • 17
                    Thanks I have just notice later that my phone it had posted first time ... but the refresh was so slow...
                    • SwisSeV
                      • Jan 2016
                      • 307
                      Why don't they provide it to you? You called the hotline?
                      • Jaws
                        • Oct 2007
                        • 235
                        This special mode you speak of will not let you change data in the e-prom. Use the original eprom that came with machine.
                        • SwisSeV
                          • Jan 2016
                          • 307
                          What makes you say that?
                          Granted I haven't done it on the models he was specifically asking about. That being said we have reset the counts in the eeprom in models like the MXM350.
                          • Jaws
                            • Oct 2007
                            • 235
                            Resetting the count is your business, but when you try to make the chip work in a different machine its Sharp business. They don't want you to move options (PS3 EXPANSION KIT
                            BARCODE FONT KIT
                            INTERNET FAX EXPANSION KIT
                            APPLICATION INTEGRATION MODULE
                            ) that you would have to pay for to another machine.
                            • ZOOTECH
                              Senior member of CRS
                              • 3375
                              If the machine does not have a 'hard' keypad, you will not be able to access the special sims; if there is a way to access special sims, it's being guarded like Fort Knox.
