MX-C311 Color Calibration
  • hRyan
    • 6
    [CQ] MX-C311 Color Calibration
    I have been working on a Sharp MX-C311 which has terrible copy quality. Another tech ran a color calibration on the machine which actually made it worse. I ran sim 44-02 and got errors on PCS_K LED ADJ, REG_R LED ADJ, and REG_F LED ADJ. I replaced both the transfer belt and registration unit with ones out of a machine that worked. Despite that SIM 44-02 still gets errors in the same places. Any suggestions on things to try or what other components might be malfunctioning?
  • bilyahn
    • Dec 2006
    • 1468
    Re: MX-C311 Color Calibration
    check your black drum K looks like all 3 errors could be related to the same thing. Front and rear registration problem as well as blk drum patch error.
    Good luck.
    Bil
    • dwarf
      • Oct 2012
      • 168
      take it apart and clean everything...then run sim 50-22 and adjust the skew...then 44-2; 44-6; 44-26; 46-24...
      Item/Display Content Setting
      range
      Default
      value
      A PCS_CL LED ADJ Color sensor light
      emitting quantity
      adjustment value
      1 - 255 21
      B PCS_K LED ADJ Black sensor light
      emitting quantity
      adjustment value
      1 - 255 21
      C PCS_CL DARK Dark voltage of color 0 - 255 0
      D PCS_K DARK Dark voltage of black 0 - 255 0
      E PCS_K GRND Belt substrate when
      the item B
      adjustment is
      completed.
      0 - 255 0
      F PCS_K BELT MAX Belt substrate input
      max. value
      0 - 255 0
      G PCS_K BELT MIN Belt substrate input
      min. value
      0 - 255 0
      H PCS_K BELT DIF Belt substrate input
      difference
      (Item E - Item F)
      0 - 255 0
      I REG_F LED ADJ Registration sensor
      light emitting
      quantity adjustment
      value F
      1 - 255 56
      J REG_F DARK Registration sensor
      dark voltage F
      0 - 255 0
      • faxman28
        • 436
        replace the resist sensor . it reads the patches on the transfer belt. it sits next to fuser and gets cooked. p/n CHLDZ2001DS53. there will be a sticker on the resist sensor unit it has the base values to enter into the sim mode , check service manual.
        • hRyan
          • 6
          I figured out the issue with your guys help. Thanks. I ended up taking the guts of the machine out again and doing another thorough cleaning. I then ran SIM 50-22 and discovered that even without turning the adjustment screws the skew values would change by more than 10 points for each lens. I replaced the LSU and started back at the beginning of the calibration and lo and behold, the errors in 44-02 were gone and the machine began producing much better quality copies.
