I have been working on a Sharp MX-C311 which has terrible copy quality. Another tech ran a color calibration on the machine which actually made it worse. I ran sim 44-02 and got errors on PCS_K LED ADJ, REG_R LED ADJ, and REG_F LED ADJ. I replaced both the transfer belt and registration unit with ones out of a machine that worked. Despite that SIM 44-02 still gets errors in the same places. Any suggestions on things to try or what other components might be malfunctioning?
MX-C311 Color Calibration
Re: MX-C311 Color Calibration
take it apart and clean everything...then run sim 50-22 and adjust the skew...then 44-2; 44-6; 44-26; 46-24...
Item/Display Content Setting
range
Default
value
A PCS_CL LED ADJ Color sensor light
emitting quantity
adjustment value
1 - 255 21
B PCS_K LED ADJ Black sensor light
emitting quantity
adjustment value
1 - 255 21
C PCS_CL DARK Dark voltage of color 0 - 255 0
D PCS_K DARK Dark voltage of black 0 - 255 0
E PCS_K GRND Belt substrate when
the item B
adjustment is
completed.
0 - 255 0
F PCS_K BELT MAX Belt substrate input
max. value
0 - 255 0
G PCS_K BELT MIN Belt substrate input
min. value
0 - 255 0
H PCS_K BELT DIF Belt substrate input
difference
(Item E - Item F)
0 - 255 0
I REG_F LED ADJ Registration sensor
light emitting
quantity adjustment
value F
1 - 255 56
J REG_F DARK Registration sensor
dark voltage F
0 - 255 0Comment
replace the resist sensor . it reads the patches on the transfer belt. it sits next to fuser and gets cooked. p/n CHLDZ2001DS53. there will be a sticker on the resist sensor unit it has the base values to enter into the sim mode , check service manual.
I figured out the issue with your guys help. Thanks. I ended up taking the guts of the machine out again and doing another thorough cleaning. I then ran SIM 50-22 and discovered that even without turning the adjustment screws the skew values would change by more than 10 points for each lens. I replaced the LSU and started back at the beginning of the calibration and lo and behold, the errors in 44-02 were gone and the machine began producing much better quality copies.Comment
