ARM_231
  • Armenator
    ARM_231
    Hi every one
    we have a problem with Sharp ARM-231 , the coustomer install a scanner unit on the machine, he buy the memory and install it to scanner unit, when he put the product key to the machine ,on the display showes up (wrong product key #) we are 100% sure that all his information such as serial Number and Application Number is Correct , IF any one had problem like this before please Help
    thanks
  • Comingapart
    • Jun 2008
    • 44
    There is no AR-M231 in Sharp's US lineup that I'm aware of.
    Do a 22-6 print out and confirm the serial number on it is the same as the one that was registered. Back panel and board swaps can cause some confusion in that area.
      • 23008
      How about AR-M237?
      • Armenator
        sorry its 237
          • 23008
          It is very easy to register the scanner key to the wrong serial number. I am aware of several occasions when this has happened. To avoid this I always check the serial # tag on the back cover and the 22-6 printoff, then re-check a third time before entering the digits onto the website.
          • Armenator
            thank you so much
