ARM450 error U2-22
  • spotlifter
    • Mar 2008
    • 65
    ARM450 error U2-22
    Need help/solutions for this code U2-22. I've tried swaping from a running m/c scanner pwd. It's still giving the same error. Any ideas?
    sigpic
    • 22996
    That's a fax memory error. I'd start out with a memory clear sim 66-10. =^..^=
    • Comingapart
      • Jun 2008
      • 44
      U2's will need to be cleared with Sim 16 or it won't go away.
      If it clears, do a firmware update.
      If it doesn't clear, try swapping in a new MFP board.
      I've seen corrupt firmware do this several times.
      If the firware update keeps returning NG, then replace flashroms or do a CN burn with known good roms and re-flash w/ latest version.
      Had that very same problem today.
      • spotlifter
        • Mar 2008
        • 65
        Not working. The machine doesn't have fax. I even cleared all memories. Thanks anyway.
        I did use sim16 to clear it. But after power off/on back, the problem still there. I guess I'll go for the firmware updates.
        But I don't know how. Whats the newest firmware? Can you send to me pls?
        sigpic
