error in print im3511
  • dvdlar2005
    When I print with Windows gives the following error
    Cable tested and is safe.
  • SwisSeV
    • Jan 2016
    • 307
    Re: error in print im3511
    What model?
    That attachment is too small to read.
    • SwisSeV
      • Jan 2016
      • 307
      Oh, that's a Cannon.
      This is the Sharp section.
        • 23008
        Actually SwisSeV, this Oce' is a rebadged Sharp AR-M350N series, but I can't make anything of the photo either. Maybe you can attach a smaller image? You might also check what driver version, what driver emulation, what driver manufacturer, etc, etc. =^..^=
        • SwisSeV
          • Jan 2016
          • 307
          Haven't seen that one yet, thanks blackcat.
          • dvdlar2005
            Drivers are tested and safe.
            Another solution do you know?
            • CopierTechofOmens
              Agitating Artificer
              • 268
              The printer is printing out the literal commands that are being sent instead of translating them into an image. I would delete the driver entirely of Maharat's computer and download the latest one. Try a different driver PCL6, PCL5e, or PS(If enabled)
              Also make sure the firmware is the latest.
              If nothing has changed on the network or with the computer then it could be the controller PWB.
              sigpic
              • dvdlar2005
                Where I can download last firmware for im3511?
                فرستاده شده از GT-I8552ِ من با Tapatalk
                • ZOOTECH
                  Senior member of CRS
                  • 3375
                  Check your print settings, that looks like the hex dump is checked.
                  But this rebadge may not have that option.
                    • 23008
                    You haven't said what application is being used to open the document. It looks to me like it's XVI32, and probably not the correct application. Unless I see some more specific answers, I think that's all I'll have to say on this topic. =^..^=
