sharp mx2610n loosing yellow
+ More Options
Posts
  • garrycmsi
    • Jun 2015
    • 22
    [CQ] sharp mx2610n loosing yellow
    customer called and said color is off when i went there i ran sim 64-1 and found no yellow. replaced the drum and yellow came back customer called two days later with same thing again any ideas
  • faxman28
    • 435
    Re: sharp mx2610n loosing yellow
    check the transfer belt unit, there is a roller/shaft that sits next to the yellow transfer roller in the belt unit this roller will pop out of place and effect the yellow color.. /before I found out about the roller/shaft, would have different issues with yellow dropping out and coming back in.
    • techmann
      • May 2016
      • 41
      These machines have a tendency to suck the developer out of the developer unit also. The drum will short out, causing DV material to stick to the drum. It all ends up in the Waste toner bottle. Sometimes you can replace drum and DV, but sharp says they had some issues with the High voltage PWB. The PWB isn't that expensive, so it wouldn't hurt to replace all three.
      • garrycmsi
        • Jun 2015
        • 22
        thanks for the ideas i checked transfer unit rollers all are fine.yellow developer appears to be under toned, there is also yellow toner residue on transfer belt ?
        • Leebs14
          • Feb 2014
          • 456
          Techmann is right it sounds like HV pwb. I had what sounds the exact same problem apart mine was Cyan. Changed drum, charge and Dev, worked ok for a week then same problem. Changed HV pwb, and drum, Dev again and never been back to it since.
          • techwurk
            • 127
            The fact that you change the DV and all is good for a day or two before the problem returns leads me to think after market toner issue as a possible cause
            When I started servicing copiers they used toaster ovens for fusers.....I'm old
            • nottoosharp
              • 266
              In other mx models I've found it to be the toner drive pack. This happened on four machines last year. Though they were older models. If you have a parts machine it is a relatively easy repair.
