Sharp SF7850
  • Machelle
    • Jul 2025
    Sharp SF7850
    What is the crop code for sharp sf7850 to turn off developer light. Thanks for your help
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    20 turns off the dev light and 42 the pm light but remember the machines telling you to change the dev for a reason. If you leave it to long the copies will go faint and possibly start eating toner and going straight into the drum unit and you will end up spending more than just replacing the dev.
    Incontinentia Buttocks
    • DavePo
      • Jul 2008
      • 305
      I have found that the best way to turn off the developer light on that model was to unplug machine and haul it to a landfill. The worst thing I ever saw from Sharp was the 7800 7850 7855
      • banginbishop
        grumpy old git
        • Oct 2007
        • 894
        so sad that you should be so hatefull to such an unreliable peice of crap
        You do know about kama - the bas***d machine would do your back in putting it in the landfill
        • Phil
          • Feb 2005
          • 16
          20 is the service reset 42 is the developer reset.
