What is the crop code for sharp sf7850 to turn off developer light. Thanks for your help
Sharp SF7850
20 turns off the dev light and 42 the pm light but remember the machines telling you to change the dev for a reason. If you leave it to long the copies will go faint and possibly start eating toner and going straight into the drum unit and you will end up spending more than just replacing the dev. -
so sad that you should be so hatefull to such an unreliable peice of crap
You do know about kama - the bas***d machine would do your back in putting it in the landfillComment
