MX4111 Machine keeps saying change waste container
  • driving lots of miles
    • Jun 2016
    • 403
    We have a MX4111 Machine keeps saying change waste toner container. We have checked sensor and waste auger motor and both work okay. Customer takes out the container and reinstalls it and it works for a few days before then the message comes back. We have supplied them with new genuine containers but the problems keeps coming back. Any ideas would be appreciated. The machine has been in the field for 3 1/2 years.
  • sharptech1
    • Oct 2011
    • 163
    Re: MX4111 Machine keeps saying change waste container
    New containers usually solve this in my experience. Seals wear out. Try firmware
      • Jun 2016
      • 403
      We have tried both firmware and new waste containers.
      • sharphead
        • Aug 2009
        • 285
        I've seen this too, with a MX4112. Firmware is up to date. Also happening with new waste toners.
        I noticed it printing with the waste toner out of the copier, but was that surprised I couldn't replicate this.
          • 23010
          Have you thought about disassembling and vacuuming out the waste toner auger system? I'd also consider changing any of those lovely Sharp 73 photointerrupters that might be used to detect waste toner auger operation. =^..^=
          • techwurk
            • 127
            That fact that the customer removes the waste container and reinstalls it, then it works... would lead me down the faulty sensor road
            When I started servicing copiers they used toaster ovens for fusers.....I'm old
            • faxman28
              • 435
              CPLTM6569DS56 replace this part item sect45 item 501 in mx5111/4111 parts . . it is the waste toner motor assembly..
              there is a switch (waste toner full switch) that is probably faulty. But the complete waste toner motor assembly could be covered in toner dust. no sensors or magic, the waste toner motor turns a coupling that turns a paddle in waste toner box. as waste toner fills, the paddle becomes harder to turn the coupling assembly starts to slip and the waste toner full switch is activated and waste toner full message on display.
              • ZOOTECH
                Senior member of CRS
                • 3375
                Excellent explanation.
                  • Jun 2016
                  • 403
                  We have ordered a waste toner motor assembly and plan to install it when it arrives. There is no toner dust and it is a clean office environment. Will let everyone know if this solves the problem. Thanks for all the reply's.
                    • Jun 2016
                    • 403
                    We replaced the waste toner motor assembly today and the error message went away.
                    Thanks for everyone's input.
