error code L4 - 31
  • wim
    • Aug 2016
    • 12
    [Error Code] error code L4 - 31
    I've recieved by power on the error code: L4 - 31.
    After reading......I understood one or two paper cooling fan, and located both fans (open right door, at the top)
    Also: Run sim 6-2 to check if the fans are connected.
    Maybe stupid, but.....how to start the sim test programs?
    I read into the technical manual: press "code mode key", then "Program key", then "*", then "clear key", then "*", then your sim program.
    This is absolutely chinese for me..... (and I am dutch)
    none of the keys are responding, because a error message: call technical service, code L4-31
    Is somebody able to explain that to me in normal words how to reach the sim test programs??
    were is the "code mode key"? item 2 in picture, see attached image
    were is the "program key"
    And the "* " is item 8 ??? ( see picture)
    And clear is item 5 ???
    thanks in advance !
  • nottoosharp
    • 266
    Re: error code L4 - 31
    thanks in advance !
    [ATTACH=CONFIG]34007[/ATTACH]
    #*c*
    • nottoosharp
      • 266
      So 9858
      • nottoosharp
        • 266
        Just change the fans, and the hdd cooling fan.
        • wim
          • Aug 2016
          • 12
          Thank you so much !!!
          I found it.
          And also both fans are not running. I opened the back cover, and checked the HDD fan, but that one is running well.
          Strange, I expected one fan dead, but two? tomorrow I'll check this, maybe a loose wire or connector.
          So, I will remove the paper cooling fans tomorrow, and if they are faulty, see if they are available somewere.
          Thanks again for the hints!
          Wim.
          (sorry for the poor english.....I'm dutch.)
          • nottoosharp
            • 266
            All the fans are the same. So if you have a parts machine you can use them.
            • nottoosharp
              • 266
              Part number NFANP0082FCP1
              • ZOOTECH
                Senior member of CRS
                • 3375
                I found it.
                Wim.
                It is not unusual for both fans (above the fuser) to fail soon one after the other, but at same time - a bit unusual. It is best to replace both at the same time if only one fails.
                Your English, by the way, is better than some that are native English speakers, IMHO.
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  Hint:
                  How to reduce the noise/vibration with cooling fans :
                  If you want to prevent CPU cooling fans or similar fans from vibrating and creating a noise, remove the metal based sticker/label from the center of the rotory blades. The label glue becomes soft and moves the label off center creating just enough vibration and noise to reduce the life of the fan. I have proved this to many associates over the years. Those assocates complain of noisy CPU or video card fans where I have no such problems.
                  A tad of trivia for the serious computer gamers out there...
                    • 23009
                    I don't know how much time it will buy you but those fans can be disassembled.
                    When you remove the round sticker there is a plastic retaining "C" ring on the motor shaft. with that removed you can slide the fan blades off, then lubricate the bearings. Mine were generating a cloud of iron oxide dust. A few drops of light oil and some manual spinning got that fan back up and running. And yes, both fans quit within 3 weeks of each other. =^..^=
                    • NeoMatrix
                      Senior Tech.
                      • 3513
                      Yes true, there is nothing inside those fans. I quick drop of silicone grease/oil on the brass bush an off they go again.
                      • wim
                        • Aug 2016
                        • 12
                        part NFANP0082FCP1
                        Is this for real: ????? $ 112.00 each?
                        Sharp NFANP0082FCP1
                        NFANP0082FCP1 Archives - Printer Parts Store
                        I'll try first to fix it with the hints given here.
                        First....removing the fans is also a little tricky.....
                        • nottoosharp
                          • 266
                          Do you have a parts machine? Maybe a boneyard?
                          • nottoosharp
                            • 266
                            We pay less than half of that for hours so I'm it might be worth doing a little shopping around because if you consider how much time it takes to remove the parts how much time it takes to repair the fans and the fact that you'll be back in a couple weeks to do all of that over again that really will be a savings either to you or to the customer by just replacing them
                            • wim
                              • Aug 2016
                              • 12
                              I removed both fans, and looked around (type the partcode on top of the fan, 2408NL-05W-B56) and found some friendly prices: $ 32 each:
                              NMB-MAT 2408NL-05W-B56 Server - Square Fan 2408NL-05W-B56, T01
                              or $ 25,14 each:
                              Original Nmb 6020 2408nl-05w-b56 24v 0.09a Line Cooling Fan 2408nl-05w-b56 Online with 25.14/Piece on Linda111's Store | DHgate.com
                              now see if they are shipping parts to the Netherlands, and the shippingcosts.
                              answer hopefully tomorrow.
                              thanks guys for your help.
