Re: Black Dev in Colour Dev Units
No!! Lol...put your black dev into your magenta unit or what ever then set up as usual with 25-2 once completed then run your sky shots to swap out the black toner with the magenta. The toner density sensor just detects toner level not colour so it doesnt know its not magenta dev so set up as if it was magenta. So technically you are not over filling the dev unit with toner you are just naturally replacing the black with magenta as it automatically replenishes the toner level so no ee-el etc. Hope this helps.
