MX-C311 won't set up in sim46-74
  • CopierCare
    • Aug 2015
    • 24
    [CQ] MX-C311 won't set up in sim46-74
    This MX-C311 is way off on color. Too Magenta. Tried to run color balance sim 46-74. Prints out test sheet and goes on the glass and reads but never prints out second sheet. Just sits there. Also when I run sim 50-22. Faults it with sub yellow front 41 or sub black 10 or main Magenta 36 faults and won't pass. Put in new drums, new developer, and new transfer belt unit. No change. Too much Magenta and color registration is off. Any ideas?? Been through the manual 20 times!
  • nottoosharp
    • 266
    Re: MX-C311 won't set up in sim46-74
    Run a 50-20 use 11X17 paper. Use the print to adjust reg. You may have to run it several times to dial it in. Change developer as well. I've ran into this several times, and this always handles it. Good luck.
    • harleyrider
      • Oct 2011
      • 348
      pretty tuff to get a c311 to run 11x17
      • nottoosharp
        • 266
        I don't know that particular model. I usually just run the box machines. Lol.
        • nottoosharp
          • 266
          Worst part of that is I just set one up a few weeks ago. Whoops.
          • techwurk
            • 127
            Double check that all lenses are clean, maybe a PCU issue, just a guess.
            You can if you fold it in half first, haha
            When I started servicing copiers they used toaster ovens for fusers.....I'm old
            • nottoosharp
              • 266
              I don't see any jamming resulting from that. Lmao.
              • spanky
                • Sep 2012
                • 468
                Go to sim 50-10 and set A to 100
                Go to sim 50-20 and set all of the color adjustments to 100
                Rerun 50-22 and adjust accordingly, this adjustment should work.
                If it does work then you can run 46-74 to get your halftones right.
                • nottoosharp
                  • 266
                  Except setting all to 100 isn't always the fix it should be.
                  • spanky
                    • Sep 2012
                    • 468
                    Setting to 100 is resetting to factory settings.
                    The settings can get maxed out after they have been run and several times.
                    You then run the 50-22 to set it for the individual machine.
                    Works for me every time, unless there is a problem in the machine.
                    • faxman28
                      • 435
                      These settings should work , it is a bulletin or tech tip from Sharp , have used these settings when the mfp has nervous break down. Also check the process sensor(or what ever sharp calls it) it reads the patches on the transfer belt for your calibrations and densities. it sits below fuser on this model and will melt from the fuser heat. search the forum , it's a post from a couple years ago.
                      • OlliK1969
                        • Nov 2016
                        • 311
                        50-20 set all to 100 A,B,C... I , or more ??
                        Have a MX-3110N with F2-45
                        • nottoosharp
                          • 266
                          Setting to default would be great except if default always worked right then there would be no adjustments to made. When you run the print you will see front side and rear side center. The colored indicator line needs to be centered front and rear for each color regardless of the numbers. Machines age, are subject to being jarred while being moved, etc...
                          • nottoosharp
                            • 266
                            Check your transfer belt, and image density sensor.
