ARM 550 Jamming 1st tray
  • tomislav
    • Nov 2011
    • 30
    Hi i have 2 different Sharp ARM 550 N,jamming in the first tray(for multiple pages).I've changed the tires,tork limiter,sensor above the first tray and the drive unit for 1 st and 2 nd tray and the machines are still jamming from the first tray (the second tray works fine).
    Can anyone HELP.
  • sharptech1
    • Oct 2011
    • 163
    Re: ARM 550 Jamming 1st tray
    Jam code?
    • nottoosharp
      • 266
      Can anyone HELP.
      Just had this happen. Check fuser drive motor. No joke.
        • 22996
        Originally posted by sharptech1
        Jam code?
        You beat me to it. =^..^=
        • tomislav
          • Nov 2011
          • 30
          [QUOTE=sharptech1;542442]Jam code?
          First thing in the morning
          • tomislav
            • Nov 2011
            • 30
            jam code?
            appd1_s;a1npd_n;pod1-n;pfd2_nm2;pfd2_nad
            • nottoosharp
              • 266
              [QUOTE=tomislav;542455]
              Jam code?
              On the key pad from the copy screen punch in this sequence: #*c* . This will put you in simulation mode. Then 23 start. 2 start. (23-2)This will print a list of your jam codes. If you share with us the codes we can help you better. Hit system settings twice to back up to the initial menu then hit 22 start 6 start (22-6) this will give you a list of sim settings, and the age of all consumable parts. This will help you know what is coming up for repair. Share top page of both sheets so we can better help you.
              • dwarf
                • Oct 2012
                • 168
                the first two codes you listed were duplex unit jam codes...check around the duplex unit...
                • JLSam
                  • Jun 2015
                  • 605
                  Third one is before fuser, but that fourth one according the manual is when PFD2 is not reached when printing from Tray 4, and that last one is when that same sensor is not reached, but it's coming from Duplex.
                  I suggest you clean the transport rollers in the duplex unit, check to see if anything is stuck, like a piece of ripped paper.
                  Check section 6 - 49 in service manual. Good luck!
