laser unit AR M450
  • swagreis
    • Jun 2008
    • 92
    laser unit AR M450
    an error code appears L6-10 which means change laser motor
    i change it with another one but another code appears E7-02 appears
    it means an error within laser unit
    is there any adjustment to laser unit to repair that error
    anyone can help
  • gordie
    • May 2008
    • 83
    Hi
    I would re check all the connectors you had removed
    Gordie
    sigpic
    • swagreis
      • Jun 2008
      • 92
      i did this operation in different machines and check well cables but the same result
        • 23009
        A lot of questions come to mind.
        You say that it was another laser. Does that mean new, refurbished, used-known good, used-unknown (possibly no-good)?
        If this laser came from another copier, did it come from a AR-M280N, AR-M350N, AR-M450N, AR-M355N, AR-M455N, MX-M355N, MX-M455N?
        Only the AR-M450N laser will work. All the others are different, too different.
        It can be difficult to seat those ribbon cables just right. Or one of the conductors could peel away from the backing, and not make a connection. Ribbon cables are not repairable. If damaged replace it. =^..^=
        • swagreis
          • Jun 2008
          • 92
          i bring this motor from ar m350
          i think the part number is the same number RMOTP0910FCPZ
          if not pls inform me the right part number
          • nftech
            If you have moved the external board for the ccd.loosen one of the screws and move the board slightly [only a hair at a time]
            You can correct the e7 problem.
            I assume you have replaced the polygon motor.
            The board can be easily knocked out of place by just mishandling
            the laser unit.
              • 23009
              I have always replaced these lasers as complete units. If there are any interchangable parts I am not aware of them. =^..^=
              • mrfixit
                Senior Technician
                • Sep 2007
                • 83
                There is a small screw that secures the laser unit on the top and that originally had the blue glue on it, make sure this screw is not tightened fully, and make sure the LSU height is adjusted.
