vertical line issue arm.236
  • GREATMAN
    • Jul 2015
    • 49
    [CQ] vertical line issue arm.236
    Thanks because i know u will respond.i have done the following.
    1.cleaned optics and.mirrors.
    2.Cleaned the lsu and serviced the drum.and.developer unit.
    3.Changed drum,cleaning blade and charger is good.
    4.Cleaned.the mylar and side door.
    5.Heater unit is okay. What am i missing?
  • bilyahn
    • Dec 2006
    • 1470
    Re: vertical line issue arm.236
    Did you actually change the cleaning blade? From your image I would say that it is the cleaning blade that is your problem. Have had this happen quite often on this series of machine.
    Good luck.
    Bil
    • GREATMAN
      • Jul 2015
      • 49
      Thanks for your reply.yes sir.i changed cleaning blade
      • vlad_
        • Jul 2008
        • 98
        Originally posted by GREATMAN
        What am i missing?
        Make a printout of the memory of the SIM 64-1, 2 And see if there is a band or not.
        • dwarf
          • Oct 2012
          • 168
          it looks like it might be a score line from a separation pawl in the fuser... run a blank sheet..
          • OlliK1969
            • Nov 2016
            • 310
            Change the charger please
            • GREATMAN
              • Jul 2015
              • 49
              Sorry for replying late i found out that there was a rust inside the scanner.
              • lky1978
                • Mar 2009
                • 483
