Sharp AR C150 - Error H5-01 -
  • Sharpcopy2000
    • Jun 2025
    Hi,
    i have a problem with my Sharp AR-C150.
    In the fusing unit was 3 or 4 times a paperjam.
    Now i can not copie and there is a error " H5-01 ".
    Please help me.
    Thanks.
  • JustManuals
    • Jan 2006
    • 9838
    From the service manual:
    POD/DPID do not detect 3 sheets of paper continuously. Check the installation of the fusing unit.
    HtH
    Paul@justmanuals.com
      • 22995
      You've defined it perfectly. 4 jams then H5-01, which means you've had four jams in the fuser.
      To clear the error code: Remove undiscovered paper jams from fuser pawl area (left door). P > interrupt > C > interrupt > 14 > Start > Execute > CA
      • Sharpcopy2000
        Further H05-01
        Hello
        thank you for the tip.
        I tried it.
        First i pressed "P",
        then i pressed "C",
        then I pressed "14",
        then I pressed "Copy",
        in the end i pressed "CA".
        Unfortunately the error message does not leave. Every time I press a key i receive a key-beep.
        Do I make which wrongly?
        The jamming of printer paper is completely away.
        Thank you very much
        Elke.
        • spotlifter
          • Mar 2008
          • 65
          Are you sure you follows blackcat instruction correctly?
          He said "P" --> "Interupt" key --> "C" --> "Interupt" key --> 14 --> "Start/Copy" --> "Execute" --> "CA"
          sigpic
          • Sharpcopy2000
            Many thanks
            I would like to thank.
            It has functioned.
            M a n y t h a n k s for the help.
