Sharp MX-7040N No Power (machine will not come on at all)
  • oleonwukah
    • May 2017
    • 12
    [Dead] Sharp MX-7040N No Power (machine will not come on at all)
    I bought this machine secondhand and got it through airfreight, i plugged machine and tested a few photocopies and powered off the machine to attach finishers, machine will not come on again! I noticed humidity inside the machine, i opened the back of the machine but will not trace if there was any burn and it looks complicated. I have bought the Sharp MX-7040N Service Manual online and the PDF file is quite bulky upto 700mb and i dont know what to do or where to go. Any help from anyone with experience on this machine will be highly appreciated...
  • bilyahn
    • Dec 2006
    • 1470
    Re: Sharp MX-7040N No Power (machine will not come on at all)
    Couple of things to look for.
    1 If it was working and THEN you attached finisher the finisher is probably the issue.
    2 there is an involved procedure to troubleshoot a dead machine but what it boils down to is on the front panel is your small green power light on, flashing or off. Depending on that will get you in the ball park. Probably an SD card/ROM issue as Sharp's are notorious for this.
    Good luck.
    Bil
    • oleonwukah
      • May 2017
      • 12
      Good luck.
      Bil
      Thanks bilyahn, it worked even after attaching the finishers, everything worked perfectly well, i turned off the machine and later turned it back on to see that it died and didnt come on again. i have detached all finishers but it still did not work, there is no sign of lights or power at all, its a total blackout. The troubleshoot you mentioned, please can you give me a clearer procedure to execute this? i am a newbie to sharp machines.
      • Jack79
        • Jul 2014
        • 312
        If you are newbie then first question in my mind is 'Did you switch on main power button?'
        • oleonwukah
          • May 2017
          • 12
          Yes, i did turned on the power and i was able to successfully photocopy some test pages, trouble came after i had powered off the machine to come back later and it didnt work anymore
          • Dadofmykids
            • Dec 2016
            • 27
            IN the USA, I would check the breaker box where the electricity enters your building. Then test the outlet.
            • harps05
              Field Service Engineer
              • Mar 2012
              • 114
              As mentioned above, pretty sure these need to be run off two seperatre circuits.
              • rudysemira
                • Oct 2016
                • 108
                Check and inspect the power board if there is a blown fuse or try to remove all wire connected from power board then connect it again.....
                • oleonwukah
                  • May 2017
                  • 12
                  Thanks guys, i opened the back cover of the machine and traced the power boards with my meter, it shows there is power input up to a point its supposed to connect to the secondary power board but the voltage is not there
                  • oleonwukah
                    • May 2017
                    • 12
                    Any suggests to solving this problem will be highly appreciated. All suggestions and advice didn't seem to work, I wonder what the real problem could be as to why this machine hasn't worked ever since I tried to turn it on again
                    Sent from my SM-G935F using Tapatalk
                    • driving lots of miles
                      • Jun 2016
                      • 403
                      It sounds to me like your are at the stage where you need to call the nearest sharp dealer and have tech support sent out. Otherwise you have a large paperweight.
