Mx2310 blurred image
  • Leebs14
    • Feb 2014
    • 457
    [CQ] Mx2310 blurred image
    I've got this problem on a mx2310. Black prints are fine but colours are not lining up, when I go into 50-22 to adjust drum alignment I get an error message?
    See photos, help??
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Mx2310 blurred image
    See photos, help??
    Check the primary transfer belt, especially the drive gear.
    Also, check the belt lift operation.
    • VBS Tech
      • Nov 2016
      • 12
      Like Zootech said check the primary transfer drive gear, i have seen this problem several times. the gear can look intact from the outside but the oval cavity that the pin locks into can tear and only skip every couple rotations.
      • spanky
        • Sep 2012
        • 468
        If not the gear go to sim 50-10 and set A to 100
        Then go to sim 50-20 and set all of the colors to 100.
        Rerun sim 50-22 and it should work.
