h5-01 error pls help!!!
  • pepengagimat
    My printer has an error message h5-01. I know I have to clear the paper and input p*c*interrupt*c*interrupt*14*start but whenever I press P, nothing happens
  • johnbla
    • Apr 2005
    • 94
    Nothing is suppose to happen when you press 'P'.... follow the sequence 'P' Star 'C' Star, THEN the display will go blank... input the number 14 and press 'Start' ...
    What Model of machine?
    regards
    John
    sigpic
    " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
    • pepengagimat
      I see. Ar-C270. got it to works. thanks johnbla. although another thing is someone printed glossy paper in it, now the fuser (?) melted the paper, leaving pieces of it on the fuser. I also saw some of the red layer scrapped off. Is this going to be a problem?
      • johnbla
        • Apr 2005
        • 94
        If the coating of the Fuser roller or the Pressure roller is damaged ... it will cause copy quality problems... print missing or additional marks on the paper... this will get Progressively worse, until every copy causes jams in the Fuser..
        Best to get someone 'Sharp' qualified to look at it.
        regards
        John
        sigpic
        • pepengagimat
          alright. thanks for the help man
