Sharp AR-507 F2-37 ?
  • upperfuser
    • Jul 2025
    19 years fixing copiers and I hate DIGITAL MACHINES!!!!! Any idea how to fix. Clean the drum of toner? Thanks in advance. Rob
    • 23009
    F2-37 is a drum mark gain adjustment error. The drum mark sensor to the rear of the drum unit may be dirty, or the drum mark may be damaged.
    If the drum mark sensor is dirty, you may have a leaking lower cleaning seal, a drum blade that is not cleaning, or overtoning of the developer.
    If you have a damaged drum mark (the 13mm x 13mm square toward the rear of the drum surface) it may be a scratched drum, normal wear, or just the wrong type of drum. Not all Cougar drums are interchangable. The F2-37 is one of the symptoms for that.
    Once the problem is resolved run simulation 44-02 to automatically adjust drum mark gain. =^..^=
