AR-M277 / AR-FN6 - FIN_INPDND jam
  • MHeon71
    • Oct 2008
    • 489
    I am getting FIN_INPDND jams. I replaced the fuser rollers and cleaned rollers, problem went away. Jam comes back about a month later, clean rollers, problem went away for a couple of days. Any ideas would be appreciated.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1885
    Should be an FN5 finisher on an M277. That jam code means the inlet sensor for the bridge wasn't reached. If you can output to the center tray fine, then that eliminates the fusing section. Plus I would think you'd get a POD2_N jam if it was the fuser. My guess might be the solenoid the runs the gate for the upper delivery unit. That or the gears not meshing with the lower unit, but I would believe that would be POD2_S. Hope that helps.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23007
      On the FN5 try reseating the connector next to the stapler. =^..^=
      • mtech
        • Mar 2007
        • 307
        If I remember correctly there is a gate that directs the paper to the finisher or the center tray. If it is out of position or warped it causes intermittant jams.
        • MHeon71
          • Oct 2008
          • 489
          Thanks for the info. I reseated the connector, the guide does not seem warped and I cleaned out the solenoid. I am replacing the guide and solenoid just in case, important customer.
          • MHeon71
            • Oct 2008
            • 489
            Just to let you know, the problem so far has been solved by replacing the POD2 sensor. I got the idea from the post about the AR-M277 with the job seperator that jammed half way out of the upper exit with no jam code. I have tested it for a week and no jams yet.
            Thanks for your help.
