MX-4100n - Image on pages shrunk.
  • oeshuron
    • May 2008
    • 259
    Tech went out to look at machine. Did power cycle and pulled cable from wall for awhile and prints returned to normal. Just wondering if this is a precursor to something and if so what it would be. 22-6 printed on a 1/4 of the page he said. Laser? PWB?
  • dsmith46
    • Oct 2016
    • 81
    Re: MX-4100n - Image on pages shrunk.
    Those pictures look like they were copies from the glass, correct? I have seen an MX5070 machine do this to copies from the glass or ADF. I ended up having to replace the entire scanner unit. Replacing just the CCD did not fix the issue. If it is doing it on internal prints, like you suggest, then I'm not 100% sure, but more than likely a board that is starting to go bad. Good luck!
    • oeshuron
      • May 2008
      • 259
      All prints including 22-6 were similar.
        • 23008
        My guess would be laser. I've seen a couple cases where the image size was changed (usually blown up or shifted 4" to one side) and the laser fixed it. =^..^=
        • spanky
          • Sep 2012
          • 468
          Could be the registration clutch is hanging up and throws off the timing of the paper
          • oeshuron
            • May 2008
            • 259
            If a power cycle and plug pull fixed the issue I think I am leaning more towards pwb or laser.
            • JLVisser
              • Jan 2018
              • 15
              Best way to check this is to interrupt a print job, pull the primary transfer and look at the image on the belt, then you'll know for sure.
              • oeshuron
                • May 2008
                • 259
                Problem returned. Replaced laser tested ok for now. Put the customers laser in a different machine to test for a bit.
