Sharp MX4100n H5-01 after trouble cancel...
  • Service@PRT
    • Oct 2016
    • 181
    This client gives a call of H5-01 after i use sm 14. Copy and print is blank on output paper.
    First time i encounter this problem.
    Need advise thanks.
    Sent from my HUAWEI VNS-L21 using Tapatalk
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • clark
    • Sep 2016
    • 109
    Re: Sharp MX4100n H5-01 after trouble cancel...
    First thing is check the gear on the transfer belt 1. It stripes the pin for the gear and will give you the h5 code and blank copies.
    • niceville318
      • Feb 2014
      • 43
      That code refers to 5 continuous jams at POD1. With blank images, I would reset the power, clean the rollers in the paper path and check the sensors in Sim 30-1 along with the following out of the manual:
      H5-01 5 times continuous POD1 not-reach
      jam
      Cause A fusing jam is not canceled completely. (A jam paper remains.)
      POD1 sensor trouble. Check & Remedy Replace the POD1 sensor.
      Fusing unit installation trouble. Check the installing position of the fusing unit. Replace the fusing unit.
      Connector, harness connection trouble. Check connection of the connector and the harness.
      PCU PWB trouble Replace the PCU PWB.
      Use SIM14 to cancel the trouble.
      • daileyrobn714
        • Jan 2018
        • 31
        Need advise thanks.
        You're going to need a new fuser
        Sent from my SM-G930V using Tapatalk
        • Service@PRT
          • Oct 2016
          • 181
          Updates...
          As i checked the machine..
          Gear is working good in transfer belt.
          But there is no toner marks on drums even in transfer belt.
          I've checked laser unit and its shutter seems fine. I even checked high voltage board all good.
          Heater from what i can see is good as well.
          So thats makes me wonder.
          • daileyrobn714
            • Jan 2018
            • 31
            Updates...
            I've seen this one other time. The toner was empty
            • clark
              • Sep 2016
              • 109
              check the second transfer belt. If hard wont turn and same problem you are getting. jams and no transfer of toner.
              • daileyrobn714
                • Jan 2018
                • 31
                Concur
                • clark
                  • Sep 2016
                  • 109
                  also check the black developer unit for developer in case you were having dv pull. Did you try color copies and see if there was any color ?
                  • Service@PRT
                    • Oct 2016
                    • 181
                    No color nor black print out.. in either copy, print from sc or that comes from computer, so its totally blank pages that is coming out of the machine.
                    • clark
                      • Sep 2016
                      • 109
                      sounds like the power supply for the main coronas is bad. Don't know how to check it.
                      • daileyrobn714
                        • Jan 2018
                        • 31
                        Inside the processing unit it rest above the drum
                        • clark
                          • Sep 2016
                          • 109
                          On top on the drums in the transfer unit. The power supply will be in the back of the machine in about the middle of the machine.
                          • daileyrobn714
                            • Jan 2018
                            • 31
                            Ok, thanks.oops I commented on the wrong model. Sorry about that.
                            • JLVisser
                              • Jan 2018
                              • 15
                              You say there's no toner on the drums? Sounds to me like your shutter solenoid is not opening. How did you test to see if the shutters open all the way? Remove the black shutter temporarily and see if you get image.
