Sharp MX4100n H5-01 after trouble cancel...
+ More Options
Posts
  • Service@PRT
    • Oct 2016
    • 181
    #16
    Re: Sharp MX4100n H5-01 after trouble cancel...
    Originally posted by JLVisser
    You say there's no toner on the drums? Sounds to me like your shutter solenoid is not opening. How did you test to see if the shutters open all the way? Remove the black shutter temporarily and see if you get image.
    i didnt say that there is no toner.. toners is new and Genuine, all of them... i will check about that shutter test when we got there today.
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
    • Service@PRT
      • Oct 2016
      • 181
      #17
      Thanks.. it was the shutter.. in someway it is stuck and not opening.
      Sent from my HUAWEI VNS-L21 using Tapatalk
      • JLVisser
        • Jan 2018
        • 15
        #18
        There is a solenoid that opens the shutters. That solenoid is probably bad. You can test it with Sim 6-1, LSUSS.
        • Service@PRT
          • Oct 2016
          • 181
          #19
          Yep checked that one... And its all good now. Thank you again.
          • JLVisser
            • Jan 2018
            • 15
            #20
            You're welcome!
              No color nor black print out.. in either copy, print from sc or that comes from computer, so its totally blank pages that is coming out of the machine.
              i'd clean the contacts for ALL colors on TBelt... if you do a stop print is there image on the drums?
              • niceville318
                • Feb 2014
                • 43
                #22
                Have you tried updating or re-flashing the firmware?
                You say you're getting blank pages. So the mfp is not jamming anymore or is it still printing blank pages and jamming at the POD1 sensor?
                With this model I've had to disconnect the mother PWB and PCU PWB, reseat all connections for a similar problem. good luck
                • Service@PRT
                  • Oct 2016
                  • 181
                  #23
                  Thanks guys.. it was the shutter who has a problem. The solenoid is bad enough for the shutter not to open. So i just changed the solenoid and all good.
