Sharp MX B402sc Fuser part
  • guitar9199
    • Sep 2016
    • 1099
    Hey gang,
    I'm rebuilding a fuser unit for a 402SC, and I'm having trouble locating a part number. In the parts guide under Fusing Unit 2, I see the number for the lower oil roller, but no number is listed for the cleaning roller for it.
    Does anyone know what that might be?
    Thanks in advance...
  • sharpie
    • Feb 2011
    • 180
    Re: Sharp MX B402sc Fuser part
    Its a supply item included with the MX-B42CL
    • guitar9199
      • Sep 2016
      • 1099
      Thank you... I didn't think this one applied since it has a cleaning web, and the 402sc doesn't use a web.
      • JLSam
        • Jun 2015
        • 605
        B42cl doesn't have web... Just opened one from box. No web, just cleaning rollers and cleaning plate. It's what you need.
        Sent from my ONEPLUS A5000 using Tapatalk
        • guitar9199
          • Sep 2016
          • 1099
          You RAWK!! Thanks a lot... Hope to return the favor.
          • Toner Boy
            • Aug 2007
            • 357
            For maintenance contracts I'm considering skipping those items and just replacing the upper/lowers. If you replace all items, you may as well buy a new unit - especially considering the labor that goes into it. Lower roller might last longer w/out cleaning roller pressing on it. Will update if fuser wear increases a lot or poor fusing occurs.
            • jp74msj55
              • Oct 2014
              • 146
              Here is kit for heater rollers. MX-B42HK You save about $62 for rebuild kits. Takes me about 35 minutes to rebuild one.
