Customer called with this today. I understand it is a lift code for tray 1. Does openinf and closing the trays usually take care of this? I thought I had this once on tray 2(U6-02) and there was nothing actually wrong. Thank you for any help. Frank/ActionPhotocopy
Sharp AR-M450 with U6-01
You need to execute SIM 15 to clear the tray trouble. -
Usually what causes this is the customer setting the endstop back too far then installing paper to the end stop. The paper misses the paper empty sensor, and the lift motor keep driving until an overcurrent condition occurs. It's trying to push the paper through the upper frame.
Yes, usually sim 15 will reset this with no additional damage. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
