753 fusing
  • poekeypop
    • Feb 2014
    • 17
    [CQ] 753 fusing
    Ive got a 753 not fusing on top n bottom of paper (8 1/2 x 11). Basically front n rear of fuser. Have replaced lfr,bearings, webs. Does not appear to be anything bent or otherwise out of sorts. Temps ok. Actually runs smooth. Seems to b the first 1"-1 1/2" from top and bottom, middle3/4 of page ok. ????? Been at this 18 years. Never ran into this.
  • ZOOTECH
    Senior member of CRS
    • 3374
    Re: 753 fusing
    Sorry for asking, but are the pressure release screws loose?
    • wpcadet
      • Jun 2011
      • 22
      Re: 753 fusing
      Yes, pressure is released fully both ends. Anyone had these springs relax or wear out ?
      • moose55
        • Mar 2017
        • 143
        Re: 753 fusing
        I have seen, on occasion, the pressure springs break in Sharps. I'm not meaning to put down your intelligence, but when the pressure is on in these the screws need to be completely loose (as in you think they will fall out). The reason I say this is because we have had techs swear the pressure was on in these fusers, and I have found they were thinking backwards. Have you replaced the collars that go inside the hot roller bearings?
        The Moose is loose!!
        • wpcadet
          • Jun 2011
          • 22
          Re: 753 fusing
          Pressure release screws are totally loose...UFR replaced, new collars, new bearings, new spacers. All 3 lamps have continuity.
          • moose55
            • Mar 2017
            • 143
            Re: 753 fusing
            The only other thing that I would suggest is swapping the fuser if possible? It is fuser related, and has to be a unit problem if temps are all ok. It would seem to me that there is something off with the pressure then.
            • dwarf
              • Oct 2012
              • 168
              Re: 753 fusing
              I'll bet that 8 1/2 X 11R or legal fuses properly... sound like the press roller to me
              • mansart
                • 852
                Re: 753 fusing
                do a skyshot.....
                panic stop machine with lead edge into fuser.
                remove jam backward and check nip width
                should be even front to rear.
                if not, with what you have replaced......definitely try press roll
